okay. The wire harness that plugs in to the three coil packs has a wire that comes out of the harness and has a small resistor block on it and is mounted to the valve cover next to oil spout. Its purpose is road noise for the radio. that wire and all three red wires in harness are connected. The casing on this wire had become brittle and was showing exposed wire. While the engine was running the wire got arched to the valve cover. The motor turned off just like if you had turned off with the key. And has not started since. i figured i had blown a fuse. i had no blown fuses. i have replaced all relay switches. i have replaced sensors i felt were associated with ignition and spark. cam and crank sensors. but still, it turns over but won't start. even tried a different ECU that had same part numbers.
Jan 23, 2025 at 5:51 AM
