Engine intermittently shuts off and on, electrical/ignition?
60,000 MILES • 5.2L • V8
EZARC FOC
Engine intermittently shuts off and on and sometimes has to be restarted going down the road.
Apr 28, 2023 at 7:19 AM
  • 55,694 POSTS
Most of the time this will be a fuel pump or the crankshaft angle sensor. When the engine stalls see if it will run on starting fluid, if so, the problem will be fuel related.
Here is a guide to help and the location of the crankshaft angle sensor so you can check it out:
https://www.2carpros.com/articles/engine-stalls
Apr 29, 2023 at 5:39 AM
