Intermittent starting
193 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RICH KAY
my vehicle has an ignition problem. Sometimes it starts and sometimes I have to turn the the key a few times. I get no ignition noise at all sometimes it fires right up?
Jun 25, 2018 at 5:08 AM
  • 55,746 POSTS
This sounds like a starter issue. When the engine will not crank over use a test light on the starter trigger wire which will confirm the starter issue. Here is a guide to help you fix the problem:
Cheers, Ken
Jun 27, 2018 at 6:10 AM
