All lights work but brake lights do not. Checked fuses all okay.changed brake light switch.
May 2, 2017 at 4:18 AM
HMAC300
✓Experienced Mechanic
check to see if you have power going to brake switch then out then trace green/red wire for lights. It may be a bad turn signal switch as it has to go through that to work lights in rear.
