Headlights dim
197,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BERRY4271
Just bought car wrecked in front. Passenger side headlights work fine the driver side headlights are on but very dim and the bright and dim are on at same time. Replace bulbs and checked the ground did not do any difference.
Jun 23, 2018 at 11:49 AM
Good morning.
Do you have a volt meter to do some voltage checks?
You need to verify the voltage at the orange wire at the headlight that is dim.
Do that with the connector off first then check it with the headlight hooked up.
Jun 24, 2018 at 12:14 AM
BERRY4271
Thanks Roy, I checked orange wire unhooked 12 volts when hooked it was 8.6.
Jun 25, 2018 at 8:30 AM
Okay, that is why it is dim. You have a voltage drop in that wire back to the fuse box. Check the voltage at the fuse block and see if it is the same.
Jun 25, 2018 at 9:38 AM
BERRY4271
Roy Thank you! It was the ext. light fuse was blown. Lights work great now. Thank you
Jun 25, 2018 at 10:49 AM
You are welcome.
Good job finding it.
Jun 25, 2018 at 10:50 AM
