Starts with starting fluid, but will not start with fuel pump manually turned on?
150,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
VIPERKING75
  • 58 POSTS
Vehicle was sitting for 5 years, replaced both front and rear fuel pumps, not getting ground at relay from ECM, during crank. Vehicle will start with starting fluid, but won't start with fuel pump manually turned on, where can I look to find what's causing ECM to not provide ground?
Feb 26, 2025 at 11:35 AM
  • 55,710 POSTS
This can be because of bad ignition module even though is has spark or I have seen a bad MAP sensor not tell the computer the engine has vacuum which will not turn the fuel pumps on. Have you run the codes to see if any are stored?
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Here is the locations of the map sensor which I would try swapping out. Check out the images (below). Please let us know what happens.
Feb 28, 2025 at 10:23 AM
VIPERKING75
  • 58 POSTS
No codes are pulling up, I've replaced the fuel filter and pressure regulator as well, and Noid test confirmed I've got injector pulse. I'm having trouble understanding why it's not starting even with the fuel pump manually jumped at the relay though.
Feb 28, 2025 at 12:15 PM
  • 55,710 POSTS
That is a good sign, did you check the inertia switch? Did you check fuse O in the under-hood fuse panel? Here are the wiring diagrams so you can see how the fuel system works. Check out the images (below). Please let us know what happens.
Mar 1, 2025 at 2:46 AM
VIPERKING75
  • 58 POSTS
Yes, inertia switch, tank selection switch, relay and fuse are all working correctly, my fuel pressure Guage isn't working properly though so I can't tell exactly how much pressure there is when the pump is forced on, it shows 0 but the test port sprays out at a decent rate when valve core is depressed.
Mar 1, 2025 at 3:26 AM
  • 55,710 POSTS
The fuel pressure gauge shows 0? this would be the problem then.
Mar 2, 2025 at 2:26 AM
VIPERKING75
  • 58 POSTS
It's a faulty gauge, it isn't depressing the core of the test port, I can assure that there is much more than 0 PSI.
Mar 2, 2025 at 3:11 AM
  • 55,710 POSTS
Did you swap out or check the vacuum line to the MAP sensor?
Mar 3, 2025 at 2:26 AM
VIPERKING75
  • 58 POSTS
Vacuum line is fine, replaced MAP, still won't start.
Mar 4, 2025 at 4:47 AM
  • 55,710 POSTS
hmm, so no codes, the engine has spark, and fuel pressure and all the fuses are good. let check the power and ground for the PCM and if okay I would replace the ignition module and then the PCM with a rebuilt unit. Please use this guide below to help check the power and ground. Please use the wiring diagrams above.
Please go over this guide and get back to us.
Mar 5, 2025 at 12:44 AM
VIPERKING75
  • 58 POSTS
I may have found the issue, I found a mouse nest under the intake, there's a chance the injector wires for half the engine have been chewed up, I will check and update after I get the intake removed.
Mar 6, 2025 at 12:37 AM
  • 55,710 POSTS
Good find! I can't tell you how many times rodents cause these kinds of problems.
Mar 7, 2025 at 12:55 AM
VIPERKING75
  • 58 POSTS
No damage to any of the wires, however I did find that almost all of the injectors were completely clogged, flushed out the fuel rails and ordered new ones. will update if it works.
Mar 15, 2025 at 2:15 AM
  • 55,710 POSTS
Yep, bad tanks of fuel can clog the fuel injectors, have a good weekend, happy wrenching!
Mar 15, 2025 at 3:33 AM
