Electrical issues?
115,000 MILES • 4.2L • V8 • 2WD • AUTOMATIC
ANDREWDUMONT
I went to start my car. I had just previously driven it maybe an hour beforehand and when I went to start it, I had power and my dash cluster lights, headlamps, radio turned on, but after about 5 seconds it would just shut off all electrical out. if I try to turn it over as soon as I did I'd hear one click and no electric throughout the entire vehicle until I opened up a door then it would let me try to crank it over again with the same result I thought it was my starter which is a pain I got down to the starter and the positive going to the starter was pretty loose so I tighten that back up put everything back together and I'm still having the same problem when I turn it over I hear one click and then nothing no electrical or anything.
Dec 4, 2022 at 5:18 AM
  • 110,248 POSTS
It sounds like you have a weak connection at some point. Are the battery terminals clean and tight, free of corrosion? Have you checked the ground wire from the battery to the engine block and body?
Take a look through this link and let me know if it helps:
Take care and let me know what you find.
Dec 4, 2022 at 1:18 PM
