The front finish panel that controls the A/C radio etc., has not power to the A/C?
88,000 MILES • 3.5L • V6 • TURBO • 4WD • AUTOMATIC
JANEKPL22
The front finish panel that controls the A/C radio and the likes has no power to the Portion that controls the A/C.
Aug 11, 2023 at 4:03 AM
  • 55,710 POSTS
The first thing we need to do is check the fuses, here is a guide that can help and the fuse panel locations:
If the fuses are okay it sounds like the BCM when out but to be sure let's do a CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the BCM out in case you need it, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Aug 12, 2023 at 3:21 AM
