Electrical/Circuits?
170,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
NICOLE JADE WECHTER
While testing my fuses using a logic probe (test light which has 2 alligator clamps which connect to both positive and ground), I'm getting a ground reading (green light instead of red) on several of my fuses. The fuses are for brake lamps, parking lamps, headlamps, O2 Sensors, injector circuit, ign, and others I can't recall. Is that normal?
Feb 18, 2023 at 11:20 PM
  • 55,808 POSTS
Yes, this is normal, the tool with show a ground to the system is not activated because the system is connected to ground when the power is not on. Let me know if you have any other questions, use 2CarPros anytime.
Feb 19, 2023 at 3:32 AM
NICOLE JADE WECHTER
Much appreciated! I was mostly sure this was the case, but I wanted to be certain!
Feb 19, 2023 at 6:12 AM
  • 55,808 POSTS
Yep, we are here if you need us, please have a nice day.
Feb 20, 2023 at 4:47 AM
