Electrical charging issues
5,347 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JIMBO81
  • 9 POSTS
I have been having an issue with the charging system in my vehicle. I purchased this vehicle from a lady online super cheap as it was not running and sat for three years. It was her husband's! He had turned this into a drag car so everything was gutted it was all motor no accessories. I went through and cleaned out the tank,fuel lines,new plugs,wires,dizzy,coil,cap,etc.etc. i hand turned the engine to get it pre lubed it fired right up no hesitation! I then noticed voltage dropping every time I rev it or put a load on it. Cool! I bought new battery and alternator. Fired it up and took it out. Noticed drop in voltage again. At idle there is no drop only under a load! Now mind you, car was gutted, wires mickey moused and engine is from another unknown vehicle! I bet you are saying "go ask the previous owner idiot!" Lol I totally would if he was alive! He died with all the secrets to this build he had going. Anyways. I have the car idling poorly. voltage is at 12.6v now I'm going to perform the test of alt. Or battery so I disconnected - terminal on batt and woke up a beast. I have high idle volts are at 15.2 and climbing so I shut it off and here I am. I don't know jack about electrical. somebody please help!
Dec 21, 2019 at 9:26 PM
Good morning,
Do you mean you disconnected the battery while the engine was running? Really?
That is not a test of anything. You never do that as you can damage the alternator.
Please explain what you did to test the alternator?
Dec 21, 2019 at 9:34 PM
JIMBO81
  • 9 POSTS
What I did was I started the vehicle and I removed the negative side of the battery to see if the vehicle would shut off. if the alternator was bad it would shut off correct?
Dec 21, 2019 at 11:57 PM
No, again that is not a test and can damage the alternator. Never ever do that.
Chances are the alternator is bad at this point. I would return the alternator and get a replacement and then retest.
Dec 22, 2019 at 12:11 AM
JIMBO81
  • 9 POSTS
I have the new one installed now!
Dec 22, 2019 at 1:10 AM
Okay, what is the charge rate at idle?
Dec 22, 2019 at 1:33 AM
JIMBO81
  • 9 POSTS
It is at 12.2v at idle.
Dec 22, 2019 at 2:05 AM
JIMBO81
  • 9 POSTS
It's dropping every time I rev and put a load on.
Dec 22, 2019 at 2:08 AM
Make sure the belt is tight.
Dec 22, 2019 at 2:54 AM
JIMBO81
  • 9 POSTS
Update: well you're right it was the belt. while I didn't have a tight I had to go buy a new one and the old one was stretched. problem solved 12 hours later thank you.
Dec 22, 2019 at 6:10 AM
JIMBO81
  • 9 POSTS
I hate electrical with the passion.
JIMBO81
  • 9 POSTS
I do have another question for you. I have a 2004 Jeep Grand Cherokee special edition 4.0 L California emissions bank 1 sensor 1 it's pulling that p0031 I've changed out the O2 sensor twice now and check engine light goes out 10-15 minutes later it comes right back on same exact code.
Dec 22, 2019 at 6:12 AM
Glad to hear it is fixed. Good job.
As far as the other vehicle, site rules are 1 vehicle per question.
If you would go back to the beginning and start a new question, we will be happy to help you.
Dec 22, 2019 at 6:17 AM
JIMBO81
  • 9 POSTS
My apologies. thanks a million.
Dec 22, 2019 at 7:49 AM
No worries. We will just pick up on another thread.
Dec 22, 2019 at 7:50 AM
