Electrical battery and alternator
68,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
RAEFISH37
I've replaced the power steering pump and the alternator and the serpentine belt and the battery. The past three weeks it just does at random sometimes it will start back up other times I have to get a jump. Then like three days ago my shifter stopped moving out of park and my push start won't shut off without disconnecting the battery. is there anything you can think of that would cause this?
Jun 23, 2019 at 9:06 AM
  • 55,721 POSTS
The first thing we should do is run the codes. here is a guide to help us get started:
Couple questions, have you installed a new battery recently? Is there any warning lights on?
This guide will help you load test the battery to confirm the failure:
Jun 24, 2019 at 12:50 PM
