electrical
250,000 MILES
DEREK LEADLEY
Battery and brake lights on the dash wont go out whilst driving.the batteryand alternator have been tested and are fine all terminals and leads have been cleaned including the earth.the veh is petrol alt belt is in place.
Apr 19, 2013 at 3:01 PM
  • 31,937 POSTS
Brake light may be due to low brake fluid, what is the actual alternator charge rate voltage?
Apr 19, 2013 at 6:43 PM
JAGGERJACK06
  • 14 POSTS
Also check the duty cycle of the alternator, it may be charging at the correct voltage but the ecu may not be switching it off. Alternatively, the Tritons have an 'L' terminal wired into the connector at the alternator. Basically the 'L' terminal is a signal wire to the ECU to tell it that it is charging the battery and switches off the light due to the ECU seeing a signal from the alternator. However, if the signal wire is damaged or broken, the ECU will get no signal from the alternator and think that it is not operating (althouiugh we know it is) and bring up the indicator lamp. Hope these suggestions help
May 21, 2013 at 11:43 AM
  • 31,937 POSTS
you checked anything yet?
May 21, 2013 at 9:15 PM
