Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Electrical
Battery
Drain
electrical
1995 PONTIAC GRAND AM
130,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
LARRY LUDWAR
MEMBER
Battery goes dead after a day or two of no use pull alarm fuse problem goes away what is fed by this fuse to cause this
Nov 23, 2016 at 11:33 AM
WRENCHTECH
Experienced Mechanic
Looks like the ABS, the dash cluster and the alarm module.
Nov 24, 2016 at 6:13 AM
It sounds like you have an ABS controller relay that is sticking on which is common, unplug it first to see if the drain goes away.
Please let us know what you find so it will help others.
Best, Ken
Nov 26, 2016 at 12:51 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
