electrical
130,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
LARRY LUDWAR
Battery goes dead after a day or two of no use pull alarm fuse problem goes away what is fed by this fuse to cause this
Nov 23, 2016 at 11:33 AM
WRENCHTECH
  • 20,760 POSTS
Looks like the ABS, the dash cluster and the alarm module. https://www.2carpros.com/images/external/42381152.gif
Nov 24, 2016 at 6:13 AM
  • 55,588 POSTS
It sounds like you have an ABS controller relay that is sticking on which is common, unplug it first to see if the drain goes away.
Please let us know what you find so it will help others.
Best, Ken
Nov 26, 2016 at 12:51 PM
