Where is the MAP sensor located?
244,450 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOHNATHON WOFFORD
I am replacing the MAP sensor and don't know where it is located to be able to replace it.
Feb 27, 2021 at 12:30 PM
  • 110,248 POSTS
The Manifold Absolute Pressure (MAP) sensor is mounted to the front of the intake manifold air plenum box. It's approx behind the alternator. To remove it, simply turn it counterclockwise a 1/4 turn. When you reinstall it, make sure the o-ring is in good condition and sealing.
Here are the directions. The attached pics correlate with the directions.
__________________________________
2007 Dodge or Ram Truck RAM 1500 Truck 2WD V8-5.7L VIN 2
5.7L V-8
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Manifold Pressure/Vacuum Sensor Service and Repair Removal and Replacement Sensor-MAP Removal 5.7L V-8
5.7L V-8
5.7L V-8
pic 1
pic 2
1. Disconnect electrical connector at sensor by sliding release lock out. Press down on lock tab for removal.
2. Rotate sensor (3) 1/4 turn counterclockwise for removal.
3. Check condition of sensor O-ring.
Installation is the reverse of removal.
___________________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 27, 2021 at 1:14 PM
