Possible parasitic battery drain
165,000 MILES • 3.4L • 2WD
JENGA VENTURE OLSEN
I believe it's a parasitic battery drain. After many tests the only fuses that remain hot with the ignition off are the fuses 29 and 33 in the engine compartment. And on the glovebox fuse block it's the fuse for cluster battery. Also, on the inside the fuse for pcm/passkey/cluster is hot on both sides with the fuse pulled.
Oct 19, 2021 at 7:33 AM
  • 110,248 POSTS
Is the light in the glove box staying on when the door is shut?
Take a look through this link. It discusses the most common causes of a parasitic electrical draw and how to locate one.
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know if that helps or if you have other questions.
Oct 19, 2021 at 1:36 PM
