Will not start and codes p1128, 422, 134 and 303
138,675 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
#1SAINTSFAN
  • 16 POSTS
something keeps dragging the battery down. i have checked the alternator and battery all good car. wont start it has a p1128 , 422,134 codes and 303. what do I do next to fix this car?
Oct 8, 2019 at 9:38 PM
  • 110,248 POSTS
Welcome to 2CarPros.
You have a few things happening here. First, does the starter engage and turn the engine? Have you checked for spark and for fuel pressure?
Next, the P1128 indicates a very lean fuel mixture. Basically, either the fuel pump isn't supplying enough pressure or there is a major vacuum leak. Here is a link dealing with finding a vacuum leak:
The P0422 deals with a catalytic converter issue. Was the vehicle lacking power prior to it not running?
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
The P0134 indicates bank 1 oxygen sensor 1 is not working. Check to see if it is unplugged or the wiring is damaged.
Let me know if any of this helps.
Oct 11, 2019 at 9:59 AM
