Are the 1997 and 1999 F150 window switches compatible?
Nov 2, 2019 at 11:36 PM
✓Experienced Mechanic
Good morning,
Standard cab? Quad cab? Are they both the same body style?
Nov 3, 2019 at 12:32 AM
SCGRANTURISMO
Sure, a switch is a switch is a switch is a switch. All the switch does is close a contact to roll the window up or close a contact to roll the window down. Being that they are both Ford's they should be compatible. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Nov 3, 2019 at 12:35 AM
DNSTAR
MEMBER
both the same body Lariat. 2 window style.
Nov 3, 2019 at 12:36 AM
On the 1999, I need the production date.
It would help if you can get the number off the switch you are replacing.
Images (Click to enlarge)
Nov 3, 2019 at 12:38 AM
There are different switches for the different years.
