Bad battery?
2004 FORD F-150
160,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JACOB LASITER
I got into my vehicle and heard a relay clicking before I even put my key into the ignition. Put the key in and entire dash was not working. Head lights still worked, power seats still worked and locks still worked. Car did not even try to start, no interior lights no radio. Not even mileage will come up, or starter even engage. The relay that was clicking when I got in was the turn signal relay. Also found blower motor fan would be running with the key in the off position. As soon as I turn the key in the on position blower motor would stop. Also found the security lights would blink rapidly for one minute then it would blink no specific pattern but very slowly. Yes, I checked the battery, alternator and changed the relay. If anyone could help I would greatly appreciate it.
Mar 14, 2021 at 3:26 AM
Is the relay still clicking or did that stop after you replaced it?
Did anything happen to this vehicle? Any chance it sits outside and have you had any thunderstorms lately? It sounds silly but it may have been struck by lightening. Check the antenna and make sure the tip is not melted or burned.
If there are no signs of a lightening strike then we need to start with checking for codes.
I am thinking we have some at least related to the theft light but let's start with this and work through this. Thanks
Mar 15, 2021 at 11:44 AM
