electrical
133,390 MILES • 3.4L • 6 CYL • AUTOMATIC
LINDA DUBREUIL
i turn off the ignition take out the keys turn off headlight switch, but all the lights stay on. headlights back lights, instrument cluster they will not turn off. sometimes when they do turn off and i go back after a little while. all the lights have turned on by themselves the only way to turn them off is to unplug the battery.
Feb 11, 2017 at 1:35 AM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes may be a body module problem.
Feb 11, 2017 at 2:58 AM
LINDA DUBREUIL
I did scan. There were no codes.
Feb 11, 2017 at 4:05 AM
HMAC300
  • 48,601 POSTS
if you used a scanner bought at auto parts it will not pick up any thing other than engine/transmission codes.
Feb 11, 2017 at 4:55 AM
