Electrical on the fuse box?
287,678 MILES • 5.2L • V8 • 4WD • AUTOMATIC
ASANCHEZ4913
On the fuse box in the engine compartment have white connector and it has 2 blk and brn stripe wires. I need to know where they connect to. Also have a solid white wire need to know where it goes to then a thick wire black and pink stripe come off one of the big fuses in the middle and 2 white and pink wires coming in need to know where these 6 wires connect to.
May 28, 2025 at 11:11 PM
  • 55,616 POSTS
The black with pink stripe goes to the combination flasher, the black and orange (not brown) go to the ignition switch and trailer tow connector, I don't see a white wire, or the white with pink or the think black wire either, can you upload an image of what you are talking about?
May 30, 2025 at 3:10 AM
