Electrical
40,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
NORTHSIDE1221
  • 9 POSTS
Changed the ignition coils and
the battery went dead and now its a no start..Keeps blowing the cam/pre02 fuse.
Jan 21, 2016 at 7:12 AM
HMAC300
  • 48,601 POSTS
because it controls all of the items in pic see if you can get a scanner to give a code. it may be a problem at trans connector like pic.
Jan 21, 2016 at 7:49 AM
NORTHSIDE1221
  • 9 POSTS
No luck and the trans connectors look good
Jan 21, 2016 at 8:22 AM
HMAC300
  • 48,601 POSTS
then you'll have to test all the circuits involved to see if it will start also do a draw test on battery to see where the problem lies then reset security system if no manual look online.
Jan 21, 2016 at 8:33 AM
