VOYTEK1
Ever since washing van. Having electrical issues, check engine light and air bag light on cluster. lock light coming on although it never did before and vehicle doesn't have power locks or alarm.Also having issues with starting the car now. Did you ever hear of this condition? Any ideas? let me know,. thank you
May 13, 2013 at 11:46 PM
HMAC300
  • 48,601 POSTS
there is a tsb on this, you are supposed to scan first to find the area then put dielectric compound on the connector to the module.trouble is you have to find he module that is givin g problem i'd start with the pcm and body modules. lot of work to do to fix it but if it works no problem plus you have to remove eh connectors then brush the stuff on.
May 14, 2013 at 12:26 AM
