passenger side lights are dim. car will stall lights are turned on.
Nov 3, 2021 at 11:58 PM
AL514
✓Experienced Mechanic
Hello, it sounds like you may have a charging system that is not working correctly, when the headlights are turned on it may be pulling the entire system voltage too low, or there may be a short circuit somewhere that just isn't blowing a fuse. Is anything else in the vehicle now working correctly? Possibly a bad battery too.
