Engine cuts off. The coil wire to distributor is very hot?
223,000 MILES • 5.2L • V8
KANE1178
Engine cuts off. The coil wire to distributor is very hot. when cools off it will run.
Oct 7, 2017 at 1:35 AM
  • 55,746 POSTS
This happens when the coil is starting to short out and needs to be replaced, I have included instructions below to help you with the repair. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jul 24, 2022 at 5:41 AM
