Engine not starting up?
150,000 MILES • 2.7L • V6 • FWD • AUTOMATIC
HASSAN SHUAIBU
  • 40 POSTS
My car has problems starting in the morning. I discovered that there is no power going into the IAC valve from the car. I use a test bulb to check for power. Please can someone tell me what to do? The iac valve is in good shape.
Dec 3, 2016 at 1:30 PM
  • 55,766 POSTS
Hey HASSAN,
There could be a break in the wiring, here is a guides so you can follow and find the problem.
I see that there is a resistor block which the power the injectors which feed the IAC valve. Check that first.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Sep 29, 2020 at 5:38 AM
