Electrical
245,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JAYAR BELISLE
  • 6 POSTS
When i drive the cluster freaks out, the battery warning light comes on and the gauge will go to high. then after it freaks out for a couple seconds it turns off and goes back to normal. Also the radio and climate control will turn off.
I have checked all the fuses and the acc relay and all is fine.
Mar 29, 2019 at 7:52 PM
Good morning,
What is the charging voltage at the battery while it is running?
Have you cleaned the battery cables?
This sounds like a voltage issue whether high or low.
Mar 29, 2019 at 11:07 PM
JAYAR BELISLE
  • 6 POSTS
Good morning,
Battery voltage is just above normal and i haven't cleaned the cables yet.
Mar 29, 2019 at 11:29 PM
I need exact numbers please in order to help you.
Mar 29, 2019 at 11:32 PM
JAYAR BELISLE
  • 6 POSTS
I have found the problem voltage regulator was bad.
Apr 6, 2019 at 6:34 AM
Good job!
Apr 6, 2019 at 6:56 AM
