multiswitch wiring diagram needed
230,000 MILES • 4 CYL • 2WD
SMOKINGJOKER405
  • 9 POSTS
What is the oem wiring reader for the multiswitch to the dash fuse box?
Apr 25, 2021 at 2:03 AM
STEVE W.
  • 15,410 POSTS
Not 100 percent sure what you are asking for but the multifunction switch only has one wire that runs to a fuse box and that is the red and green wire on terminal 6 which runs through the dash harness to the passenger side box and fuse 10. What is the issue you are having? perhaps we can help you track it down.
Apr 25, 2021 at 3:15 AM
SMOKINGJOKER405
  • 9 POSTS
Apr 25, 2021 at 3:21 AM
STEVE W.
  • 15,410 POSTS
You're welcome, if you need more info or other wiring just ask.
Apr 25, 2021 at 3:41 AM
SMOKINGJOKER405
  • 9 POSTS
I will.
Apr 25, 2021 at 4:33 AM
