After replacing the battery there is message say the vehicle has been hit in the front and it has not been hit?
80,000 MILES • 2WD • AUTOMATIC
JTHOMAS99
My car is reading that it has been hit in the front, but it hasn't. I just got a new battery, and got everything tested that seems to be fine.
Dec 13, 2023 at 6:06 AM
DR LOOT
  • 2,311 POSTS
Changing the battery sometimes causes weird things to happen. Try erasing the code and see if it comes back on.
Dec 13, 2023 at 10:31 AM
  • 55,711 POSTS
Yep, the systems can have a glitch because of the voltage surge, I would disconnect the battery over night to see if that fixes it. If not, we need to do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Please go over these guides and get back to us.
Dec 14, 2023 at 5:30 AM
