Electrical
95,000 MILES • 4 CYL • AUTOMATIC
KRISTIN REBECCA ROUSH
Last Monday I had my car in "drive" to drive to work, all of a sudden, my CD player stopped working, the mirror on the right I was putting up stopped, and my windows would not roll up or down. I was confused so I turned off my car, and I put it in park. When I turned my car back on it still was running, but the gear shift would not go back into gear. A message popped up that said "Service Vehicle PWR STR" I have been told to check the fuses, almost all of them have been replaced and still nothing will work.
Aug 22, 2017 at 1:05 PM
SATURNTECH9
  • 30,868 POSTS
So you checked all the fuses inside the car and under the hood? If so how did you check them? Under the hood in the fuse box there are square fuses with a clear top look through the clear top to see if any of those are blown? One of those feeds power to your electric steering motor. Also, have you made sure your battery cables are clean and tight at the battery? Have you tested your battery yet?
Aug 23, 2017 at 5:37 AM
It ended up being a fuse in the interior fuse box that controls all the electrical functions
Aug 24, 2017 at 4:42 PM
SATURNTECH9
  • 30,868 POSTS
Glad to hear it was a simple fix it sounded like a fuse.Which fuse was blown?
Aug 25, 2017 at 2:35 AM
