Electrical
140,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JEANNY MONK
Engine stops intermittently, will some times start back up some times will not. Also, if I use to many accessories at once seems to overload system and results in engine failure and power loss to some functions.
Dec 17, 2017 at 1:20 AM
Good afternoon my name is Roy and I will assist.
I would start by checking the fuel pressure. There is a valve on the fuel rail you can use to test it. You can rent a tester at a parts store. You may have a failing fuel pump causing the stalling.
Start there and report back to us with the results.
Dec 17, 2017 at 1:53 AM
JEANNY MONK
I am losing power to some electrical components, I can make engine failure by rolling windows down and adjusting seat.
Dec 17, 2017 at 2:29 AM
Okay, then start at the battery. Check the voltage with the engine off and then with the engine running. Let me know the results.
Dec 17, 2017 at 2:32 AM
