Electrical
152,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JRCDADDY
Hello. I just replaced my stepper motors on my cluster. But now all my back LEDs are out. I checked all the connections and they seem good. Could they possibly be all burned out? Or maybe a fuse?
Jun 29, 2016 at 11:18 PM
HMAC300
  • 48,601 POSTS
normally the cluster is pulled out and rebuilt not just a stepper motor. Regardless it has to be reprogrammed to your car.
Jun 30, 2016 at 3:32 AM
JRCDADDY
Yes actually all the stepper motors were replaced because they were sticking. It is a common problem with this make. But now it looks like all the back lighting/LEDs are out. Possibly needs to be replaced also.
Jun 30, 2016 at 10:39 PM
  • 55,781 POSTS
You might of got an open connection, try removing the cluster again and then leaving the wiring hooked up and wiggle it to see if you can get the connection back. Its would be really rare that all the lights burned out at once.
Best, Ken
Jul 6, 2016 at 1:24 PM
