Blinkers and emergency lights do not work
106,332 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
KIMSDAD
I replaced the fuses and flasher and still nothing. any ideas?
Jun 15, 2019 at 1:50 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with Ground G202, underneath the instrument panel on the left side of the brake pedal bracket. I have included an exterior lighting wiring diagram with the ground highlighted for you in the diagrams down below as well as a guide on the proper way to check a ground. Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Jun 15, 2019 at 6:55 PM
