Horn and windows not working
100,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
MRONN
The horn does not perform.
after the right front window does not perform, also the both back windows.
i want to know the issues and the guides to solve them.
Thank you!
Mar 26, 2018 at 3:59 AM
KHLOW2008
  • 41,812 POSTS
Start off with checking the fuses and replacing any that are blown. Next would be to check/test the various components that are not working. If components are good, check for power supply to them and if available, test the switches and horn pad.
Mar 26, 2018 at 3:16 PM
