electrical?
140,000 MILES
HUNLOCKEJOE
check engine light on. OBD 2 says random misfire cylinder 6. changed plus,wires, injector coil pak, Also changed air/fuel mixture solenoid on manifold, don't know what to do now! Is it possible that the pcm has failed and only affects this issue ?
May 27, 2013 at 4:28 AM
DOCFIXIT
  • 18,828 POSTS
Has compression been checked?
May 27, 2013 at 4:35 AM
HUNLOCKEJOE
yes compression on all 6 cyliders is above 160
May 27, 2013 at 4:37 AM
DOCFIXIT
  • 18,828 POSTS
Code PO306? #6 injector replaced? have used NOID light on injector to see if it operates?Was misfirs history checked? any other codes?
May 27, 2013 at 5:29 AM
