When truck heats up the gauges go a quarter off
125,600 MILES • 4.6L • V8 • 4WD • AUTOMATIC
FORDGUY1234
when truck heats up the gauges go a quarter off. Amp hand discharge and oil pressure goes red side.
Sep 30, 2016 at 6:18 AM
  • 55,721 POSTS
Hey ford guy,
It sounds like the cluster plug might be loose or has a bad connection, can you remove the cluster and disconnect the wiring and then reconnect it?
Please let us know what you find so it will help others.
Best, Ken
Oct 4, 2016 at 3:30 AM
FORDGUY1234
Where is the cluster plug located?
Oct 8, 2016 at 3:17 AM
  • 55,721 POSTS
At the rear of the cluster
Oct 8, 2016 at 4:12 AM
FORDGUY1234
Okay thank I'll check and let you know!
Oct 8, 2016 at 5:35 AM
  • 55,721 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
Dec 21, 2016 at 6:27 AM
