Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Interior
Instrument Cluster
Gauges
When truck heats up the gauges go a quarter off
1997 FORD F-150
125,600 MILES • 4.6L • V8 • 4WD • AUTOMATIC
FORDGUY1234
MEMBER
when truck heats up the gauges go a quarter off. Amp hand discharge and oil pressure goes red side.
Sep 30, 2016 at 6:18 AM
Experienced Mechanic
Hey ford guy,
It sounds like the cluster plug might be loose or has a bad connection, can you remove the cluster and disconnect the wiring and then reconnect it?
Please let us know what you find so it will help others.
Best, Ken
Oct 4, 2016 at 3:30 AM
FORDGUY1234
MEMBER
Where is the cluster plug located?
Oct 8, 2016 at 3:17 AM
At the rear of the cluster
Oct 8, 2016 at 4:12 AM
FORDGUY1234
MEMBER
Okay thank I'll check and let you know!
Oct 8, 2016 at 5:35 AM
Hey,
Did you ever get the problem fixed?
Best, Ken
Dec 21, 2016 at 6:27 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
