Push brake to put car in gear DTR light signal flashes, then check engine comes on?
148,140 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ANGIE DILLON
I have no headlights, brake lights or turning signals?
Apr 19, 2023 at 12:10 PM
  • 55,797 POSTS
It sounds like the BCM is going out, but we need to do a CAN scan to be sure. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is how to change the BCM out is case you need it. You can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Apr 20, 2023 at 4:47 AM
