Electrical
100,000 MILES • 6.4L • V8 • TURBO • 4WD • AUTOMATIC
DOUGLASHALBERT
Temperature gauge registers hot, engine revs high.
Aug 23, 2016 at 1:46 AM
HMAC300
  • 48,601 POSTS
scan for codes, and check for a vacuum or air leak including engine grommets on valve covers. check coolant to make sure it is not low. and check to see if cooling fans work.
Aug 23, 2016 at 2:26 AM
