Temperature gauge registers hot, engine revs high.
Aug 23, 2016 at 1:46 AM
HMAC300
✓Experienced Mechanic
scan for codes, and check for a vacuum or air leak including engine grommets on valve covers. check coolant to make sure it is not low. and check to see if cooling fans work.
Aug 23, 2016 at 2:26 AM
