Turn signals are weak in strength of light output
140,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
GARY.FRANKLIN
Suspect a ground problem. The rear sequential signal grounds have been cleaned. Am proceeding on researching where other grounds are to clean them as well. Can you offer any insight to problem?
Apr 29, 2020 at 11:57 PM
  • 110,248 POSTS
It's been a long time. LOL As far as the lights, you indicated the ground is good. Have you confirmed there is 12v going to them?
As far as schematics, because of the year, they are few and far. Let me know if you confirmed 12v to them and we'll go from there. Also, I need to know if you checked the signal flasher.
May 1, 2020 at 1:32 AM
