A/C control has no power, dash lights and gear shift lights are not working?
135,000 MILES • 1.3L • 2WD • AUTOMATIC
FESSAL
Why the A/C control has no power, the lights on the dashboard were not turning on gearshift has no lights as well...the light on the clock dims when I put on the headlights...also my press start with the alarm remote no longer functions could only start the vehicle with the key... I checked the fuses all fuses are good...also my bonnet was forced open, and one headlight was stolen and from then the vehicle began giving those symptoms above.
Apr 13, 2023 at 12:56 PM
  • 110,248 POSTS
This model vehicle wasn't offered in the US during 2010, so I have very limited information. However, I will try my best to help.
Since the issues began when the light was stolen, have you checked the wiring to the lamp assembly as well as the wiring around that area? Something may have been pulled and caused a short.
Also, are all fuses good and have power to and from them?
Also, other than the items listed above, is the vehicle running properly?
Apr 14, 2023 at 1:17 PM
