Engine shut off while driving
350,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BIRDIECGARCIA
Months ago, while driving the truck shut off numerous times. It turned back on. Never fixed the problem. And two days ago it turned off on the interstate and will not turn back on. The fuel pump is working and shoots fuel to engine or whatever it is called. And replaced the alternator and still will not turn on.
Help?
Mar 19, 2018 at 3:35 PM
Good morning.
When you crank the engine, does the tachometer move up a little while cranking? that will tell us if the crank sensor is working.
Mar 19, 2018 at 9:58 PM
BIRDIECGARCIA
Yes. It barely moves.
Mar 20, 2018 at 2:24 AM
Okay, the crank sensor is sending a signal to the PCM.
The next is to check fuel pressure. you can rent a tester at a parts store to verify correct pressure.
beyond that you will need to check to see if the injectors are being commanded on by using a noid light. that also can be rented at a parts store as well.
Mar 20, 2018 at 2:27 AM
RENEE L
  • 1,260 POSTS
Hello BIRDIECGARCIA,
Thank you for visiting 2CarPros. Here is a helpful link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
If you need further assistance please come back to the site we are always happy to help.
Kindest regards,
Renee
Admin
Mar 20, 2018 at 7:59 AM
