Need exact location of starter relay and the fuse that controls the relay no diagrams on the car.
Jul 21, 2022 at 11:00 PM
✓Experienced Mechanic
I'm not sure if you have the 4 or 6 cylinders. I attached the starter circuit schematic below for both. The first two pics are for the 4 cylinder and the second is the v6.
If you look through the schematic, it indicates the location s of fuses and relays.
