Electrical?
MMMARTIN
  • 2002 NISSAN MICRA
Driving as normal then the seat belt light started blinking off and on.
then all electrical systems went no lights no speedo fuel and temp guage.
followed by a dying of power.
pulled over. Left it for some hours. Then after waiting for rescue it started like there was no problem.
Iv fully charged battery. Replaced alternator and belt.
car sort of worked fine. But wipers were slow.
then after about 7 miles. Flashing seat belt light. Erratic idling then it just conked out.
tried a jump start no problem but died fairly quick.
alternator is working.
now I'm just confused and very p'd off.
can anyone shed any light on this annoying problem.
PLEASE?
Wednesday, April 17th, 2013 AT 6:30 AM
KHLOW2008
  • 41,814 POSTS
Did you test the alternator charging?
Have the ignition switch tested.
Wednesday, April 17th, 2013 AT 6:48 AM
MMMARTIN
Alternator working within parameters and ignition switch?
I will check that. But not sure why lol.
Thanks. :-)
Wednesday, April 17th, 2013 AT 6:51 AM
KHLOW2008
  • 41,814 POSTS
A bad ignition switch can result in loss of power to certain circuit.
If vehicle is equipped with harmonic damper, have it checked as well. A bad harmonic damper can result in erratic charging.
Wednesday, April 17th, 2013 AT 7:09 AM
