Electrical
1996 MITSUBISHI ECLIPSE
182,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KYLE CORNELIUS
I can drive a short distance and then my car will either shut off or will not start back up after shutting it off. I have been able to determine that it is not a fuel issue as I am getting plenty of fuel. Can you please help diagnose this problem?
Aug 22, 2017 at 7:25 AM
  • 31,937 POSTS
do you know if you still have spark when it shuts down and will not start?
Aug 22, 2017 at 8:57 PM
KYLE CORNELIUS
It starts just fine a couple times a day, but will not run around in a constant from place to place.
Aug 23, 2017 at 5:37 AM
  • 31,937 POSTS
You need to see if you have spark at the plugs when it stops. can you do this?
Aug 23, 2017 at 7:34 AM
