Electric window switches?
236,000 MILES • 2WD • AUTOMATIC
PENNI89
Our car is a 2006 TX Ford Territory, we are trying to replace the window switches. Our master switch has 13 pins, but we can only seem to find 12 pin sets, and only suitable to the S series not a TX. Will a 12 pin still work, or do we need to find a 13-pin switch? Thank you
Aug 8, 2023 at 11:10 AM
  • 55,749 POSTS
I would try to find the 13 pin switch, it sounds like there is an accessory added to the switch that will not work with the 12 pin switch.
Aug 10, 2023 at 4:25 AM
