Electric sliding door
84,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MARCOALBERTOMARTINEZ
When I try unlocking electrically the left rear door it does not work, it locks with panel button or remote control if i unlock manually sliding door will open and close normally the right one works with out any problems.
Apr 24, 2016 at 12:24 PM
  • 55,604 POSTS
It sounds like the motor that controls the door has gone out. Remove the door panel and while using a test light check for power at the motor, if is has power the motor had gone out and needs replacing which is common with these cars.
Please let me know
Apr 26, 2016 at 1:41 AM
