engine it will not turn over
79,000 MILES • 2.8L • 6 CYL • FWD • AUTOMATIC
DEANIEBOY22
i can drive car and when i turn car off and try to crank back up it will not turn over and volt meter shows no volts. i have new alternator, battery cables, had battery checked and was told battery was good. could it be the grounds? thank you
Mar 6, 2017 at 7:30 AM
  • 55,770 POSTS
It sounds like the starter has gone bad, here is a guide on how to test and replace the starter. The test is at the bottom of the guide.
https://www.2carpros.com/articles/car-engine-will-not-crank-over
and
Please run this test and get back to us so we can continue helping you.
Best, Ken
Mar 9, 2017 at 12:44 AM
JUDY0127
car turns over won't start
Mar 9, 2017 at 1:45 AM (Merged)
SATURNTECH9
  • 30,868 POSTS
So have you checked to see what the actual fuel pressure is? Have you also checked for injector pluse?
JUDY0127
no
SATURNTECH9
  • 30,868 POSTS
You need to check that and for spark and for codes.
