Electric mirror fuse location
200,000 MILES • 3.8L • V6
JERRY LEHMANN RASMUSSEN
where is the fuse located?
May 10, 2020 at 1:51 PM
  • 110,246 POSTS
The fuse is in the left hand instrument panel fuse box. It is a 2 amp fuse. Don't use a higher amperage in place of that fuse because damage can occur.
I attached two pics below. First is a portion from the schematic in the event the fuse checks good. You can check for power to the orange wire at the switch for power. Note there should be power all the time at that point.
The second pic is of the fuse box. I circled the fuse to locate.
When you check the fuse, in addition to only looking at the fuse, make sure there is power to it. Here is a link you may find helpful:
Let me know what you find or if you need help with anything.
May 10, 2020 at 2:20 PM
Joe,
Thank you for your quick response. yes, I will check the fuse's in the morning {is 9:45 PM here} and notify you as to what I find. I am 79 years young my friend and I'm about done for this day. Thank you once again, will speak again tomorrow or Tuesday at latest. Sincerely, Jerry R.
May 10, 2020 at 2:49 PM
  • 110,246 POSTS
You are very welcome. I will watch for your reply.
May 11, 2020 at 11:15 AM
